Air only comes out of the defrost vents
90,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JDROSE0721
I replaced the blower motor and the blower resistor and they work fine, but the air only comes out of the defrost vents now. I think the air diverter actuator is bad. Where is it located and how do I replace it?
Jul 16, 2018 at 2:48 AM
  • 55,649 POSTS
You could have a vacuum line that has broken near the firewall or just inside where the heater plenum is. Here is a guide to help you see what to look for. I should have the actuators locations by tomorrow but check this first.
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Cheers, Ken
Jul 17, 2018 at 6:40 AM
