Air Not Flowing from Center Vents
85,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
PCIARDULLO
There is no air flowing from the center vents. However aire is flowing from the floor and defrost vents. I changed the cabin air filter and that did not help. Is this a big job to fix?
Jul 22, 2015 at 11:19 PM
KHLOW2008
  • 41,812 POSTS
The venting system is not working correctly and it most probably is due to a bad mode motor. Not a really big job but you need to know which part or linkage to look out for.
Jul 25, 2015 at 2:17 AM
