A/C not blowing cold air
207,302 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
KEMON25
Greetings, the heat blows fine but the air doesn’t blow cold air. I’ve recharged it and it read everything was at the measurement. what could it be? I’m totally lost and need polar cold air before the summer heat kicks in can anyone help me please?
Apr 23, 2021 at 2:53 PM
  • 110,248 POSTS
First, can you let me know what the high and low pressures are in the system? If you can, let me know the outside temperature when it was checked.
Next, is the compressor engaging when you turn the system on? Let me know.
Here is a link you may find helpful. Take a look through it to see if anything helps.
Let me know the answers to the questions and if the link is at all helpful.
Apr 24, 2021 at 2:55 PM
