Air Intake
48,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
ARMANDO1
I bought a renovated car that had been crashed on the left headlight, and caused the air box to be closer to the brake fluid and is touching something else which would then cause the gas and brake pedal to vibrate slightly when the car is running, and I would feel it especially during turns. I was wondering if over time this could be a safety problem and if I should invest in removing the air intake system and installing a cold air intake system that would not be touching the brake fluid or whatever it is that causes the brake and gas pedal to vibrate. My only reservations were that it does not seem like a cold air intake has much added benefit and might be more costly in the long term.
May 12, 2021 at 3:16 AM
CARADIODOC
  • 34,413 POSTS
Causes of transmitted vibrations like what you descried are usually very difficult to identify. Since it looks like you already know the cause, there has to be some way of repositioning parts to isolate them from each other. I have a friend who specializes in rebuilding smashed one and two-year-old Dodge trucks. I've helped him on a few, including my own rebuilder, and I've watched how he measures things and gets them back to where they're supposed to be. If your car's body panels fit properly and the gaps are uniform, it's likely this is simply a matter of locating a bent and overlooked mounting bracket, or shifting something that is adjustable.
As for that cold-air intake system, liquid gasoline does not burn. It goes out the tail pipe, wasted. The goal of the intake system is to give the fuel time to turn into a vapor that will burn.. Adding heat, especially in cold winter months, helps that occur for better engine performance. Cold air intakes defeat that.
The idea is cold air is more dense, so you can add more fuel to it to get more power. The rest of us do that by pressing further on the accelerator pedal. Regardless how you do it, you have to maintain a 14.7 / 1 mixture for most power and lowest emissions.
May 12, 2021 at 12:16 PM
