Air injection check valve replacement
89,000 MILES • 2.2L • 4 CYL • 2WD
CPERRY54
  • 35 POSTS
How do you remove and replace it?
Feb 16, 2020 at 8:42 PM
Good morning,
I attached the pictures on the replacement procedure. why are you replacing it? Do you have a code? This is not common. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Feb 16, 2020 at 9:20 PM
