Air flow though carburetor
100 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
JIM STERLING2
Engine idling putting on air cleaner cover engine shuts off.
May 18, 2019 at 12:02 PM
  • 110,251 POSTS
Welcome to 2carPros.
Is the air inlet vent on the air filter housing open or blocked?
May 18, 2019 at 2:51 PM
JIM STERLING2
Open air filter on top of carburetor (single barrel , Rochester carburetor) putting cap on carburetor stalls engine.
May 19, 2019 at 1:43 AM
JIM STERLING2
With the air - gas mixture screw where do you start or with the first setting of the screw how many turns out ?
May 19, 2019 at 1:51 AM
  • 110,251 POSTS
Welcome back:
When I first start, I take the adjusters all the way in and then back out 1.5 turns.
May 19, 2019 at 11:12 AM
  • 110,251 POSTS
Welcome back:
JIM STERLING2
I will try again !!!
May 21, 2019 at 12:42 AM
  • 110,251 POSTS
Make sure nothing is blocking the air intake tube and nothing is hitting the choke causing it to close. I realize you most likely already did, but though I would add that in case.
May 21, 2019 at 12:33 PM
