HVAC air flow only works on the defrost setting?
200,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
DPEREZ1000
The air flow is only coming out on defrost no matter what is selected on the control panel.
Oct 12, 2022 at 12:51 PM
  • 110,251 POSTS
Chances are the mode door actuator has failed. This actuator is responsible for the air flow direction. Take a look at this link:
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
What I would do is remove it and see if it responds when you change the air flow direction. If it doesn't, replace it.
I attached the directions below for the removal and replacement. Let me know if this helps or if you have other questions.
Oct 12, 2022 at 2:41 PM
