Blower sounds like it is running at all speeds, but I can barely feel it at any vent. what are my diagnostic choices?
Feb 19, 2018 at 9:31 AM
✓Experienced Mechanic
Good morning.
There is a blower resistor that controls blower speed operation. it is mounted next to the blower motor. It is the most common failure for this issue.
Feb 19, 2018 at 7:09 PM
BUZZOFF
MEMBER
All speeds are running proper i said i just cant feel it at the vent so try again maybe?
Feb 20, 2018 at 8:18 AM
It sounds like you lost vacuum tot he HVAC system. Can you check under the hood to see if you can find any small vacuum line headed to the firewall that are broken? Here is a guide to help you see what I am talking about:
Cheers, Ken
Image (Click to enlarge)
Feb 20, 2018 at 8:21 AM
BUZZOFF
MEMBER
thank you for the suggestion but, it is changing vent configuration properly just very little air flow. If I run it on high for very long it starts smelling like blower motor is getting hot, but only on high . Almost like there is some kind of obstruction. I have only had it for a week so i am still tracking all the bugs! :>(
Feb 20, 2018 at 10:37 PM
If you smell the blower on high, I suggest you replace the blower motor and the resistor. They sound like they are overheating from too much current draw.
Feb 20, 2018 at 10:58 PM
Here is a guide to help you test the power and ground of the blower motor circuit and it will show you what you are in for when doing the job:
