Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Ranier
Interior
Dashboard
Sudden loss of air flow from dash vents
2004 BUICK RANIER
110,000 MILES • V6 • 4WD • AUTOMATIC
JAYNE BUCKLES COOK
MEMBER
1 POST
All of the sudden, there's no air flow from dash vents. Air flow from floor, windshield, and backseat air flow is good.
May 21, 2021 at 12:52 AM
Experienced Mechanic
if the air is not coming from the vents only then most likely we have an issue with the mode door actuator.
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
Below is the process from the manual that will show how to replace and re calibrate this actuator. Please let us know if you have other questions or how you work out. Thanks
Images (Click to enlarge)
May 22, 2021 at 1:31 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
