air flow
93,000 MILES
FABIANMLUJAN
I just got this van and when i move the switch to modify the air flow (heater/ ac) it doesn't change. Also I can hear a hiss (like a vacuum line broken). Also i found some mice feces under and into the glove box. How can I access to the vacuum lines in order to fix it (assuming some mouse had chewed one). Thank you!
Apr 30, 2013 at 10:51 AM
the face plate for the control has to be removed and unbolt the control head and move it forward to inspect for damage
mice do a lot of damage by chewing through wire harness.
Apr 30, 2013 at 8:11 PM
FABIANMLUJAN
Thank you Roy! Is there any diagram that could show me how to get there?
Apr 30, 2013 at 8:56 PM
