Air directional door stuck
2008 CHEVROLET IMPALA
210,000 MILES
JAMC
I have replaced the left side actuator and the problem persists. The air directional door is stuck open and there is a tick-tick-ticking sound when the temperature is set to the coldest setting and the A/C comes on, but it is behind the actuator and behind the little 'drive shaft' that turns the actuator.
Solution?
Feb 15, 2019 at 4:24 AM
Good morning,
The ticking noise is the actuator motor that is not functioning correctly.
Did you replace the actuator motor? If you did and the actuator is not moving the door, then there may be something blocking the door from moving..
With that in mind, the new actuator motor is no good, as well as the plastic gears, have failed.
What exactly has been done?
Feb 15, 2019 at 4:29 AM
JAMC
"I have replaced the left side actuator and the problem persists."
Feb 16, 2019 at 8:07 AM
JAMC
I will replace the actuator motor that "drives the actuator. Thank you for your advice.
Feb 16, 2019 at 8:10 AM
You're welcome.
Always glad to help.
Feb 16, 2019 at 8:32 AM
