A/C runs intermittently
167,000 MILES • 2.5L • V6 • 2WD • AUTOMATIC
JERDOG63
  • 33 POSTS
When I a gauge air conditioner, it blows warm air and cuts on and off kind of like intermittently.I checked the refrigerant with a gauge and it fluctuated to the red and then back to low.I depressed out some of the refrigerant until it hit green area.But it still blows intermittently warm air.Do you have any suggestions Roy?
Jul 20, 2020 at 11:00 AM
There you go.
Thanks for doing that. That keeps us in good graces.
Okay, do you have a set of gauges that can read high and low side reading? I need to see those pressures to see if the Freon system is working.
What is the reading on your low gauge?
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Jul 20, 2020 at 11:07 AM
