Air conditioning will not blow cold
130,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
GONZALESABEL94
My A/C used to blow cold, but i had to change my radiator and never put the Freon. it has been a couple months since i used my A/C and now that heat is coming i did the Freon recharge myself but my A/C wont kick on. did i damage it?
Jun 24, 2019 at 9:19 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Unless there is a leak in the system allowing pressure to escape, the compressor should start when a specific pressure threshold is reached. Do me a favor. Take a look through these links and let me know if anything helps. Also, I need to know how you are recharging the unit and was it the engine coolant radiator that was replaced or something different?
The links cover a couple different techniques for adding Freon. Since I'm not sure which you are using, I'm including both.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
https://www.2carpros.com/articles/air-conditioner-leak-detection
Let me know if any of that helps or if you have other questions.
Jun 24, 2019 at 12:44 PM
GONZALESABEL94
Yes it was the engine coolant radiator that was replaced.
Jun 24, 2019 at 1:01 PM
  • 110,248 POSTS
I suspect you may have damaged one of the connectors at the condenser. That is the think in front of the radiator that actually looks like another radiator. That is my first suspect for a leak. The condenser and condenser block are attached to the radiator. Although you don't have to drain the Freon or take any of it apart, something is most likely leaking from the work.
Did you take apart the condenser?
Jun 24, 2019 at 2:00 PM
