Air conditioning system
65,000 MILES • 1.3L • 4 CYL • 2WD • MANUAL
NATHANIEL CAMPUED JR.
filter of blower gets wet.
Oct 10, 2019 at 1:58 PM
  • 110,251 POSTS
Welcome to 2CarPros.
I believe you are referring to the cabin air filter. If that is the case, I need you to check something. When using the AC or defroster, the ac is operational at which point you should eventually see water coming from it and going to the ground under the vehicle. If the drain is plugged, it may be causing this to happen. Check that and let me know what you find.
Oct 12, 2019 at 1:39 PM
