Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Truck
Climate Control
Air Conditioner
Switch
Replace/Remove
Air conditioning switch will not change from floor or legs to face or upper vents.
2002 DODGE TRUCK
217,785 MILES • 4.7L • V8 • 2WD • AUTOMATIC
KENNETH A IDLE
MEMBER
1 POST
That's all.
Sep 15, 2014 at 6:41 AM
Experienced Mechanic
The vent doors are vacuum actuated. Check for vacuum leaks both under the dash and check for the supply that will go through the firewall to the engine. Most likely, there is a leak.
Sep 15, 2014 at 11:23 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
