Air conditioning stops working
104,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MARK_HOLSTEN
  • 7 POSTS
On very warm days (nineties), cold air will only blow while accelerating. That is if the air is even blowing at all. On these warm days the air just stops blowing (even while accelerating). Any ideas?
Jun 24, 2018 at 8:10 AM
Good evening.
Do you have gauges to check high and low pressures while the AC is running?
Is the front of the radiator and ac condenser clean of all debris?
Is the fan clutch engaged and drawing air from the front?
https://www.2carpros.com/articles/fan-clutch-symptoms
Jun 24, 2018 at 10:09 AM
MARK_HOLSTEN
  • 7 POSTS
Hi Roy,
I do not have any gauges but will look into it. The condenser is definitely clear of debris as I checked that yesterday. I do not recall if the fan clutch was engaged now that you mention it. I will look into these and follow up. Thanks.
Mark
Jun 24, 2018 at 11:30 AM
You are welcome.
Keep us updated with the information so we can further assist you.
Jun 24, 2018 at 11:35 AM
MARK_HOLSTEN
  • 7 POSTS
Hello
Following up on this. I believe the problem was the harmonic balancer. It was wobbling pretty good. Having it replaced now.
Jul 8, 2018 at 5:45 AM
Okay, but that has no connection to your issue.
Jul 8, 2018 at 5:53 AM
