Recharged air conditioner filled up worked one day, next day no charge. repeated second same result. just leaks out.
Jun 30, 2017 at 11:00 AM
HMAC300
✓Experienced Mechanic
you have to fix the leak first otherwise you are wasting your money. it will need to be leak checked to find problem then you can come back for instructions on what parts need replacing along with evacuation of system with a vacuum pump.
