Air Conditioning Problem
176,000 MILES • 2.9L • 6 CYL • 2WD • AUTOMATIC
RUCHO26
When I turn the knob on the dashboard to turn the air conditioning on nothing happens, I changed the blower motor and the resistor. Also made sure to check the fuses where okay and they are. But A.C unit is still not working.
Jan 27, 2019 at 7:43 AM
SCGRANTURISMO
  • 4,897 POSTS
Hi Rucho26, my name is Alex and i will be helping you today. Here is a helpful link that might help you. Let us know if there is anything else we can help you with. Thanks. https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Jan 27, 2019 at 10:57 PM
JIS001
  • 3,412 POSTS
Does the blower motor come on but the there is no cold air coming out? If that is the case, does the A/C clutch engage? If it does not, check the air gap on the A/C clutch. You could just have a worn out clutch and replacing it should fix it. Let us know.
Feb 20, 2019 at 4:51 PM
