Air conditioning only blowing out of top vents and now not blowing cold
142,000 MILES • 7.3L • V8 • TURBO • 4WD • AUTOMATIC
NIACABO
Got the truck back shop where flushed radiator, vacuum lines to hubs replaced, along with vacuum pump. At first the air would blow cold out of defrost vents now it won't blow cold. I've replaced the hvac heating vent a/c switch, and the auto locking hub vacuum and control valve solenoid. And I tried to recharge it but it won't accept anymore Freon. Any ideas on what it could be? Its 110 outside and I need A/C soon.
Jun 2, 2014 at 12:17 PM
HMAC300
  • 48,601 POSTS
check for a vacuum leak at hvac start at motor and work your way back good possibility one of the hvac vacuum lines were left off so none of your vacuum motors in heater will work. or if yo have a water shut off valve that may be not working either.
Jun 2, 2014 at 10:53 PM
