Air conditioning not working properly
133,000 MILES • V8 • 2WD • AUTOMATIC
NINASMITH1
Truck listed above is a Silverado. Air conditioning has not been operated for many years. System has no Freon in it, 134A.
Attempted to push air out of system with refrigerant before charging. Slowly charged system. Ambient air at 76 F. Suction pressure at 30 pounds approximately. Discharge Pressure at 190 pounds approximately. inlet evaporator suction line cold. Outlet evaporator suction line is warm. Discharge air at interior 70 F approximately.
Jul 19, 2020 at 8:55 AM
I suspect you have either a leak allowing air in/Freon out or the system or you have moisture in there. Unfortunately, trying to push air out with the Freon will just not give great performance.
Either way, we need to pull it down into a vacuum and see how long it holds. It should hold it for a long time but we need to make sure it can for at least an hour.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Jul 19, 2020 at 9:05 AM
