Air conditioning not working
131,021 MILES • 2.7L • V6 • 2WD • AUTOMATIC
JESSE101050
My air conditioner is not working. My compressor turns on the clutch engages, I have plenty of Freon in the system. I am still not getting cold air everything is working properly. I have tested all the electrical test it all the everything and I still cannot figure out why it is not working. I just added to recharge to it to make sure I let some out and then I added some more just to make sure that proper pressure or testing. All the connections electrical are all working properly. Checked the relay, checked the fuses, the blower motor is working just fine. I rinsed out the front radiator that is fine. So please tell me what you think it might be. The one thing I did notice that when the AC systems on the clutch does come on and engage, but it stays on all the time. It does not start for a few seconds like it normally would when it is running and it is blowing cold air. Could that be a sign that there is something wrong with the clutch? I have no idea. Maybe you can tell me is there a possibility that even if it still might not be cold believe that the clutch is not engaging properly to turn the pump. The pump is not moving the air through the system which means the pipes on getting cold.
Jul 3, 2018 at 8:45 AM
Good evening.
Do you know the pressures on the high and low side? That would help us narrow the area of failure.
It could also be the blend door motor not allowing cold air out the vents.
Jul 3, 2018 at 9:17 AM
JESSE101050
Thank you for your help. I guess I did not take in to account the temperature out side when filling the AC system. It is ninety five degrees outside. So I spoke to my friend and he said that the refrigerant was still too low. So I added another 10 oz of Freon to the system and that is what did it. Ice cold blows nice and strong.
Jul 4, 2018 at 8:22 AM
RENEE L
  • 1,260 POSTS
Hello JESSE101050,
Please post your question regarding your 2007 Chrysler Pacifica here:
This is a different vehicle and needs to be a separate question in order for the site to correctly index it.
Thank for using 2CarPros.com and have a great rest of your day!
Renee
Admin
Jul 5, 2018 at 10:50 AM
