Air conditioning not working
2010 TOYOTA CAMRY
234,455 MILES • 6 CYL • 2WD • AUTOMATIC
FRANUEL
Hi, the air conditioner is no longer functioning, I have checked the fuses and relay but they were okay.
Feb 17, 2021 at 11:06 PM
  • 110,244 POSTS
The first thing I would suggest is to check the Freon level. If it is too low, the system will not turn on. Normally, a shop would use what is called an AC manifold set to read both the high and low pressures. With that information, you can tell if it is low.
Here is a link showing how to add Freon. Follow this link and try adding Freon. It may be low.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Also, take a look through this link. It explains the most common causes of an A/C not working.
Let me know if that helps or if you have other questions.
Take care and God Bless,
Feb 18, 2021 at 10:45 AM
