Climate Control/AC Compressor/Clutch not working. Doesn’t blow cold at all
20,000,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
TIMINCA
Turn Climate Control to Max AC and blows ambient temp air only. Heater, blower and blend doors switching works fine.Pressure Sensor has 5 VDC Ref Sig.(IN) with 1VDC(OUT) and it’s Ground. No +VDC to Air Conditioner Clutch or Engine Cooling Fans (high speed). Supply +VDC to clutch connector on compressor and clutch pulls in just fine and not only does compressor sound and work well the engine cooling fans come on also. I believe my issue is in IPDM or an open in wire returning from switch in compressor to IPDM. I need more info such as wiring diagrams, pin outs and direction to test further. Any assistance would be greatly appreciated, thank you in advance. Tim
Sep 26, 2025 at 11:32 PM
TIMINCA
Please disregard this reply
Sep 27, 2025 at 12:18 AM
  • 55,797 POSTS
Can I ask why? did you find out the problem?
Sep 28, 2025 at 4:00 AM
TIMINCA
No I didn’t find out the problem. Please any assistance would be greatly appreciated.
Sep 30, 2025 at 8:36 PM
  • 55,797 POSTS
You can be having an issue with the IPDM but we should see if you have the correct amount of refrigerant first, lets use this video to help you.
https://www.youtube.com/watch?v=uZrQCGwXfek
Is this car a 2020 year model? Please go over this guide and get back to us.
Oct 1, 2025 at 2:38 AM
