Driver's side A/C blowing hot air
179,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
JADAIR80
  • 5 POSTS
Vehicle listed above is an LS Ext with manual A/C controls
So I bought this vehicle and it is honestly a good vehicle besides the air conditioning problem. First off I replaced the water pump, thermostat, clutch fan, rear A/C housing as it was damaged, made sure the A/C is properly charged, and I am still running into the exact same problem. The front passenger A/C gets cold and even colder while driving. The rear A/C is warm unless it is night time then it is cooler some but it gets colder when I am driving. The front driver side A/C is hot no matter what and hotter if I put the blend door to hot. I am assuming the driver side blend door actuator is not functioning properly so I ordered a new one to try and trouble shoot that. Blower on the rear A/C is functioning properly as well. Help!
Aug 26, 2020 at 11:37 AM
  • 110,248 POSTS
First, it does sound like the blend air door actuator is not working on the left. Here is a link that shows how to replace one in general:
Here are the directions specific to your vehicle. The attached pics correlate with the directions.
2005 Chevy Truck Trailblazer 4WD L6-4.2L VIN S
Air Temperature Actuator - Left
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Procedures HVAC System - Manual Air Temperature Actuator - Left
AIR TEMPERATURE ACTUATOR - LEFT
AIR TEMPERATURE ACTUATOR REPLACEMENT - LEFT
REMOVAL PROCEDURE
1. Remove the I/P carrier.
pic 1
2. Remove the left side air temperature actuator (1) retaining screws.
3. Disconnect the left side air temperature actuator electrical connector.
4. Remove the left side air temperature actuator.
INSTALLATION PROCEDURE
pic 2
1. Install the left side air temperature actuator (1).
2. Install the left side air temperature actuator retaining screws.
Tighten the screws to 1.9 N.m (17 lb in).
NOTE: Refer to Fastener Notice in Service Precautions.
3. Connect the electrical connector to the left side air temperature actuator.
4. Install the I/P carrier.
5. Calibrate the air temperature actuator on vehicles equipped with automatic climate control (C68). Refer to Re-Calibrating Actuators (Primary).
________________________
If you have automatic climate control, you need to re-calibrate the actuator. Here are the directions. Note that you can do it with or without a scan tool. Without is toward the bottom of the directions.
Vehicle Heating and Air Conditioning Service and Repair Procedures HVAC System - Automatic Re-Calibrating Actuators (Primary)
When replacing the HVAC control module it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC control module be sure to perform the following:
IMPORTANT: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result.
1. Place the ignition switch to the OFF position.
2. Disconnect the scan tool.
3. Install the HVAC control module.
4. Connect all previously disconnected components.
5. Start the vehicle.
6. Wait 40 seconds for the HVAC control module to self-calibrate.
7. Verify that no DTCs have set as current DTCs.
When replacing the HVAC actuator it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC actuator be sure to perform one of the following:
IMPORTANT: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted improper HVAC performance will result.
Preferred Method (w/ Scan Tool)
1. Clear all DTCs.
2. Place the ignition switch in the OFF position.
3. Install the HVAC actuator.
6. With the scan tool, initiate the Motor Re-calibration feature of the Heating and Air Conditioning Special Functions menu.
Alternate Method (w/o Scan Tool)
1. Clear all DTCs.
2. Place the ignition switch to the OFF position.
5. Remove the HVAC B fuse for a minimum of 10 seconds.
6. Install the HVAC B fuse.
7. Start the vehicle.
8. Wait 40 seconds for the HVAC control module to self-calibrate.
9. Verify that no DTCs have set as current DTCs.
_______________________________________________
As far as the rear AC issues, the auxiliary air temperature actuator mimics the set passenger temperature. You will need to check if it is operational by removal and inspection. Here are the directions for replacement. Pics 3 and 4 correlate with these directions.
Air Temperature Actuator - Auxiliary
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Procedures HVAC System - Manual Air Temperature Actuator - Auxiliary
AIR TEMPERATURE ACTUATOR - AUXILIARY
AIR TEMPERATURE ACTUATOR REPLACEMENT - AUXILIARY
REMOVAL PROCEDURE
1. Remove the right rear quarter trim panel.
2. Disconnect the electrical connector from the air temperature actuator.
3. Remove the retaining screws from the air temperature actuator.
pic 3
4. Remove the air temperature actuator (1) from the rear HVAC module.
pic 4
1. Install the air temperature actuator (2) to the rear HVAC module.
2. Install the screws to the actuator.
3. Connect the electrical connector to the air temperature actuator.
4. Re-calibrate the air temperature actuator. Refer to Re-Calibrating Actuators (Primary).
5. Install the right rear quarter trim panel.
Let me know if that helps.
Aug 26, 2020 at 1:05 PM
JADAIR80
  • 5 POSTS
Hey Joe, I am going to go through all of this information again as it is a lot to read and I want to make sure I do everything correctly to get it working. However if you mean install the old actuators etc., then that is kind of impossible as that is the reason the previous owner tried to make such a faulty repair as he removed the rear actuators rather than buying new ones and tried screwing the blend doors into the position he wanted the thus the reason I had to replace the housing.
Aug 26, 2020 at 1:28 PM
  • 110,248 POSTS
As far as replacing the old one, no that isn't necessary. Have you already replaced them? Also, did the prior owner remove the actuators and then screw the doors into the position he wanted?
Aug 26, 2020 at 1:31 PM
JADAIR80
  • 5 POSTS
Yes! The old rear actuators were thrown out by the previous owner and he screwed the blend doors to the position he wanted.
I bought all new housing etc.
Aug 26, 2020 at 8:47 PM
  • 110,248 POSTS
Are you able to check if the rear is responding when you change temperature?
Aug 27, 2020 at 1:17 PM
