Air conditioning does not switch areas
2011 HONDA CIVIC
158,000 MILES • 4 CYL • 2WD • AUTOMATIC
OGLESCHARLES
Cannot switch from front to any other zone for the air to flow. Heating and air work fine, rear defrost works fine. Is there a way to tell if there is a short or a issue with the blend door actuator?
Nov 12, 2019 at 11:37 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds like you're having a problem with the blend/mode door actuator. It's a small electric motor the that controls air flow throughout the ducts in the HVAC box.Here is a tutorial for you to view showing how to replace:
I've attached 2 pictures below as step-by-step instructions for your Civic.Hope this helps and thanks for using 2CarPros.
Nov 13, 2019 at 9:48 AM
