Air conditioning compressor does not turn on when turned in the on position?
227,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHANE MULHOLLAND
Nothing happens when I turn the air on. Nothing happens; this was a rental vehicle so I think it might have been disconnected?
Mar 23, 2025 at 12:57 AM
  • 55,748 POSTS
Hello Shane,
The most common reason for this to happen is the system is low on refrigerant.
Here is a video to help:
https://www.youtube.com/watch?v=4UjfQKvrB6Y
If the charge is okay here is another guide to help fix the problem, I would check the fuses as well (fuse #42 in the fuse panel under the hood).
Check out the images (below). Let us know how it goes.
Mar 23, 2025 at 4:37 AM
