I can not get the air conditioning working properly
150,000 MILES • 2.5L • 4 CYL • TURBO • 2WD • AUTOMATIC
TRUONG VU
  • 14 POSTS
I can not get the air conditioning working properly; it blows very mild cold air, may be warm. Can you tell me where the actuators that open the mixed air between heat and air condition located at in the firewall of the car and how to access them? I checked air compressor, okay. air cold. Heat working okay. I think that it is the climate control module defective. Before I replace it , I would like to check if I can manually open the actuator to cover the heat opening somewhat. Other Nissan models have the cable, mine is controlled by actuator, I think. Please let me know .
thanks
Jul 21, 2020 at 12:28 AM
  • 110,248 POSTS
There are two blend air door actuators on this vehicle. I attached two pics below. Pic 1 is the left side and pic 2 is the right side. The left actuator will be on the left side of the HVAC box and opposite for the right.
Are you certain that the compressor is working properly? It's odd that both actuators would go bad at the same time.
Here are a couple links you may find helpful:
Let me know if I can help.
May 25, 2021 at 4:27 AM
TRUONG VU
  • 14 POSTS
thank you Joe. Can you tell me how to access them?
  • 110,248 POSTS
Here are the directions from Alldata. The first set of directions are for the left side. The two attached pics correlate with the directions.
__________________________
2007 Nissan-Datsun Altima L4-2.5L (QR25DE)
Air Mix Door Motor - LH
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Removal and Replacement Air Mix Door Motor Air Mix Door Motor - LH
AIR MIX DOOR MOTOR - LH
AIR MIX DOOR MOTOR
Removal and Installation
pic 1
Removal
1. Remove the instrument lower cover LH.
2. Remove the center console side finisher LH.
3. Remove the heater and cooling unit foot duct LH (2).
4. Remove the tire pressure monitoring system receiver.
5. Disconnect the air mix door motor connector (1).
6. Remove the air mix door motor screws (A) and then remove the air mix door motor LH.
Installation
Installation is in the reverse order of removal.
____________________________________
Air Mix Door Motor - RH
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Removal and Replacement Air Mix Door Motor Air Mix Door Motor - RH
AIR MIX DOOR MOTOR - RH
pic 2
Removal
1. Remove the glove box.
2. Remove the heater and cooling unit foot duct LH (2).
3. Disconnect the air mix door motor connector (1).
4. Remove the air mix door motor screws (A) and then remove the air mix door motor RH.
Installation
Let me know what you find.
