The compressor is not being activated due to an electrical fault. You need to test the power supply circuit to the compressor and its ground circuit.
Start with test to the compressor relay. Check for power supply and proper ground. The ground circuit might linked to the engine computer depending on system.
You need an auto electrician to help.
SPONSORED LINKS
Wednesday, July 6th, 2016 AT 8:06 PM
