Air conditioning only cools when idling
200,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
LARRY74
Cools while idling and does not cool when going down road.
Jun 30, 2019 at 8:47 AM
  • 110,248 POSTS
Welcome to 2CarPros.
The first thing that needs check is what the pressures are in the system. It could be too high or too low. Here is a link that explains how to evacuate and recharge a system. I am including the link because it shows the manifold gauges that are needed to check pressures. Often times, a parts store will lend or rent one to you.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
When checking the pressures, note the outside temperature and let me know both.
Here is a general link that you may find helpful too:
Let me know the results.
Jun 30, 2019 at 12:22 PM
