Where is the low pressure switch for the air conditioning?
50,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
Z534851
I need to know where low pressure switch for A/C is or if there is not one can I evacuate A/C and get a enough refrigerant in with vacuum only to get compressor on?
Jul 5, 2021 at 11:11 AM
  • 110,248 POSTS
As far as the pressure sensor, there is only one and it is referred to as an A/C pressure sensor.
Can you explain what is happening? Also, does the vehicle have automatic or manual climate control?
As far as vacuuming the system, you will need special tooling. Take a look through this link:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Also, take a look through this link. It explains what to check for an inoperative or weak A/C system.
Let me know if that helps.
Jul 5, 2021 at 2:45 PM
