Air conditioning
150,000 MILES • 3.8L • 6 CYL • 2WD
BANJOBOB1200
  • 23 POSTS
Car sat 2 years. Broke blower housing while cleaning out mouse nest. Replaced housing. Tried A/C but no cold air. Compressor cycled rapidly. Let idle for about 20 minutes and compressor cycle stopped. Tried jumping low pressure switch (LPS)but no success (later had a better jumper and it worked) never found high pressure switch. Replaced A/C relay in CCRM. Pulled vacuum and it held for 1 hour. Jumped LPS and installed 1 can 134a. Low pressure line got cold but couldn't get 2nd can to go into system-2nd can never got cold. Obviously not an A/C guy! Help!
Jun 20, 2020 at 6:47 AM
Good afternoon,
I need the high and low side readings for the ac system. that will help me determine the issue.
You can rent a set of gauges at a parts store or buy a chap set at Harbor Freight.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Jun 20, 2020 at 7:51 AM
BANJOBOB1200
  • 23 POSTS
Hey Roy, low side is 90 psi and high side is 85 psi. I initially assumed I was out of 134 and pulled a vacuum. I never tried to evacuate the system (didn't really know how). Could it be that the system was fully charged and I overcharged it? Since starting, I have been given access to a Freon collection system and I could certainly evacuate the system and charge again. Thanks.
Jun 20, 2020 at 11:53 AM
Those pressures indicate there was Freon in the system.
If the compressor was engaged, the compressor is no good.
If the compressor was not engaged, then you have an electrical issue with the compressor circuit.
Was the compressor clutch engaged?
Jun 20, 2020 at 9:11 PM
BANJOBOB1200
  • 23 POSTS
Compressor clutched after I changed the relay in the CCRM. With the low pressure switch jumped, clutch engaged constantly. With low pressure switch installed, clutch engaged at a regular, short interval. Could excess r134 cause system to not cool? (Because I initially added one 12oz can). Thanks. Won't be able to work on it until tomorrow just answering your text. Thanks again.
Jun 21, 2020 at 3:45 AM
BANJOBOB1200
  • 23 POSTS
That's "worked" not "clutched" in first sentence.
Jun 21, 2020 at 3:46 AM
Okay, just to be clear, the readings on the high and low side were when the clutch was engaged?
Jun 21, 2020 at 3:50 AM
BANJOBOB1200
  • 23 POSTS
I'm not sure. I was trying to add r134 and the clutch was cycling. The upper radiator hose burst and I closed all valves and those were the last readings I got. Never had that happen before; what a mess and very thankful for safety glasses!
Jun 21, 2020 at 4:22 AM
Okay, I need to know if the clutch was engaged.
If it was, you have a bad compressor that is not building pressure.
If it is not then you have an electrical issue turning on the clutch that we need to trace out.
Jun 21, 2020 at 4:26 AM
BANJOBOB1200
  • 23 POSTS
So do I need to hook up gauges tomorrow and record pressure during clutch cycling? In other words record pressures with the clutch turning and record pressures when clutch isn't turning? There should be a difference right?
Jun 21, 2020 at 7:33 AM
Correct.
Do those checks and post them here for me to view.
Jun 21, 2020 at 7:36 AM
BANJOBOB1200
  • 23 POSTS
Okay, will do tomorrow, thanks.
Jun 21, 2020 at 7:38 AM
You are welcome.
Always glad to help.
Jun 21, 2020 at 7:40 AM
BANJOBOB1200
  • 23 POSTS
Hey Roy, emptied manifold and before starting car or A/C the static pressures were lo-17/hi-21. Warmed car up and pressures were lo-29/hi-325 with clutch running. After warming up the clutch engaged constantly-no cycling on and off. Anything else you need and thanks again.
Jun 22, 2020 at 1:58 AM
BANJOBOB1200
  • 23 POSTS
Before car warmed up the clutch would cycle. The last reading with clutch cycling was lo-22/hi-270.
Jun 22, 2020 at 1:59 AM
The low side is the issue. 22 is too low. It should be 25-30 rock solid.
I would replace the expansion valve and the dryer and then evacuate for 1 hour and charge the exact amount of Freon needed.
It takes 34 ounces.
Jun 22, 2020 at 2:10 AM
BANJOBOB1200
  • 23 POSTS
Okay. Why, when it stopped cycling did the low go up to 29 and the hi go to 325? Also, the expansion valve is the orifice tube isn't it?
Jun 22, 2020 at 2:46 AM
That is correct. It is part of that line. Any parts store should carry that line.
Jun 22, 2020 at 3:01 AM
BANJOBOB1200
  • 23 POSTS
Like the 1st question, any idea why when the clutch remained engaged, it went to 29 lo and 325 hi. Thanks again and I'll be getting a dryer and hose with orifice tube.
Jun 22, 2020 at 3:08 AM
It could be overcharged. The expansion valve flow is minimal and allowing a back up of pressure.
Jun 22, 2020 at 3:11 AM
BANJOBOB1200
  • 23 POSTS
Okay thanks. Will order tube and dryer online and text the results. Thanks again.
Jun 22, 2020 at 3:18 AM
BANJOBOB1200
  • 23 POSTS
Replaced the suction line and dryer. Vacuum held over an hour, recharged with correct amount and now blows cold air and compressor cycles. However my fan (radiator fan) won't come on. Followed test procedure from my.streetonline and it points to CCRM. Ect working, fan works when jumped, voltage into CCRM, no voltage at fan and no voltage from CCRM. I appear to have a re-manufactured CCRM and the part number label is missing. Can I get a correct pn by using my vin? Thanks again for all your help.
Jul 28, 2020 at 1:14 AM
Okay, first, what is the high side pressure? The fan will not come on until there is at least 150-200 pounds.
Can I have the VIN number?
I attached the connector and the wiring diagram for you. Verify all powers to the unit before replacing.
Jul 28, 2020 at 5:52 AM
BANJOBOB1200
  • 23 POSTS
Hey Tom, the vin is: 1FALP4047VF109858.
I will get the high side pressure and check those powers to the unit tomorrow. I'm done for the day. Thanks.
Jul 28, 2020 at 8:20 AM
Okay, I attached the part. Rock auto has it in stock.
Jul 28, 2020 at 8:55 AM
