Air conditioning
210,300 MILES
ARTYSHA HOLSTON-DEXTER
All lights comes on when the air conditioning runs for a while. All lights come on but the car does not stop running. The windows will not roll down. What could be causing this?
Jun 6, 2018 at 7:38 AM
Good morning.
Can you explain a little more about what lights come on?
Does the air conditioning work okay?
Do the windows stop working when all this happens or do they not work all the time??
Jun 6, 2018 at 2:28 PM
All the lights on the dash, notifications lights come on battery, seat belt, engine, etc. Yes the air conditioning still be blowing, the windows do not roll down when lights come on, unless I pull over and turn key off then the lights on dash go off and power resumes to the windows. The gauges on the dash also go to the off position as if I turned the car off. But the car still be going/running. I uploaded a picture of the dashboard with lights on.
Jun 6, 2018 at 5:12 PM
From the looks of it, you are loosing communication. This could be from the ignition switch which is common for this issue.
I suggest you get it checked to be sure.
Tools Required
J-42759
Removal Procedure
1. Disconnect the negative battery cable.
Caution: Refer to SIR caution. See: Engine, Cooling and Exhaust > Technician Safety Information > SIR Caution
2. Disable the SIR system. See: Air Bag(s) Arming and Disarming > Procedures > Disabling
3. Remove the hush and knee bolster. See: Knee Diverter > Procedures
4. Remove the steering column trim covers. See: Steering Column > Removal and Replacement > Steering Column Trim Covers
5. With the key installed, turn the key to the RUN position.
imageZoom/Print
6. Install an allen wrench into the hole on top of the lock cylinder housing. Push down on the allen wrench to release the tab on the lock cylinder inside the lock cylinder housing.
imageZoom/Print
7. Slide the lock cylinder out of the lock cylinder housing.
8. Disconnect the passlock and key buzzer from the lock cylinder housing.
imageZoom/Print
9. Insert J-42759 into the lock cylinder housing to release the tabs on the ignition switch.
10. Pull the ignition switch out of the lock cylinder housing.
11. Disconnect the connector from the ignition switch.
Jun 6, 2018 at 5:27 PM
