Air conditioning suddenly stops blowing cold air?
155,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
HOLLIE L NICHOLSON
My A/C blows cold and then stops blowing cold, it has Freon in it and there’s also no leaks.
May 18, 2023 at 4:49 AM
  • 55,766 POSTS
When it stops blowing cold air, does the compressor engaged? It sounds like the compressor is going out or you have a temperature door actuator that is not working.
Here is a guide to help us get started on fixing the problem:
We should check the pressure as well, which this video can help with:
https://youtu.be/4EqdrBVb0sY
Please go over these guides and get back to us.
May 19, 2023 at 4:18 AM
