My A/C blows cold and then stops blowing cold, it has Freon in it and there’s also no leaks.
May 18, 2023 at 4:49 AM
✓Experienced Mechanic
When it stops blowing cold air, does the compressor engaged? It sounds like the compressor is going out or you have a temperature door actuator that is not working.
Here is a guide to help us get started on fixing the problem:
