Air conditioning after driving a while starts blowing warm air
184,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
PENNY CARTER
Air conditioner works when I first start car and drive for quite a while and then all of a sudden it will stop. blows really cold air when it’s working, and then starts blowing warm air after driving for a while. Not low on Freon I checked it.
Sep 2, 2019 at 10:45 AM
Good morning,
Can you give me the low and high side pressures when it blows warm? I need those readings to help determine the failure.
Does the water drip on the ground when it is running?
Sep 2, 2019 at 10:34 PM
PENNY CARTER
I haven not checked the pressure. but yes water is dripping from underneath the car when the car and air is on.
Sep 3, 2019 at 9:39 AM
Okay, you can rent a set of gauges at a parts store or buy a cheap set at Harbor Freight?
Let me know when you get the pressures.
Sep 3, 2019 at 8:35 PM
