My A/C and heat seem to only blow out no matter what the setting is at night. When using the A/C, I feel the presence of cold air when I put my hand near the vents, but it blows out the same low speed no matter what the setting is on. The same applies for the heat.
My passenger floorboard is not wet or leaking. I have changed out the blower motor and the blower motor resister. Everything seems to be connected fine. I swapped out the A/C relay and even the A/C comp diode. The Freon level is fine.
Why would I only feel the air blow out strong at night instead in the heat of the daytime when I need it most.
Jul 17, 2017 at 2:09 AM
