Compressor will not turn on?
70,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
BONES2025
Compressor won’t turn on at the control, but it will engage if I put power directly to it. Checked the fuse and freon, both are good. Ideas??
May 13, 2025 at 4:38 AM
  • 55,721 POSTS
It sounds like the low side pressure switch is out, but can I ask what is the low side pressure readings are with the system off? Also, please check the HVAC fuses # I have listed in the images below, this guide can help as well:
Here is the low side pressure sensor location so you can make sure it is plugged in, and the connection is good.
Please go over this video as well:
https://www.youtube.com/watch?v=4EqdrBVb0sY
and
https://www.youtube.com/watch?v=4UjfQKvrB6Y
May 14, 2025 at 4:54 AM
