Air conditioning
2006 DODGE TRUCK
179,300 MILES • 5.7L • V8 • 2WD • AUTOMATIC
GAVIN LOWITZ
  • 7 POSTS
The exhilarate fan stays on without the air conditioning on.
May 24, 2018 at 4:32 AM
Good afternoon.
Which fan? The cooling fan or the blower fan?
May 24, 2018 at 4:59 AM
GAVIN LOWITZ
  • 7 POSTS
Cooling fan.
May 24, 2018 at 5:20 AM
You mean the one inside the truck?
May 24, 2018 at 5:25 AM
GAVIN LOWITZ
  • 7 POSTS
No, the fan under the hood even with the air conditioner off it still runs.
May 24, 2018 at 5:58 AM
GAVIN LOWITZ
  • 7 POSTS
Even if I do not ever use it it still runs.
Okay, the TIPM or the fuse box under the hood is what controls the condenser fan.
I would remove the connector for the low pressure switch on the AC line and see if it shuts it off. If it does not then the TIPM is the issue.
May 24, 2018 at 6:26 AM
GAVIN LOWITZ
  • 7 POSTS
Is a little pressure switch located on top of the intake manifold.
May 24, 2018 at 6:28 AM
No, as I stated, it is on the AC lines, not the intake manifold. I attached a picture for you.
May 24, 2018 at 6:31 AM
GAVIN LOWITZ
  • 7 POSTS
I have had problems with that switch before the wires on top.
May 24, 2018 at 6:41 AM
GAVIN LOWITZ
  • 7 POSTS
Does that switch have a Schrader valve on it? What do you call it when you call AutoZone?
May 24, 2018 at 6:42 AM
I did not tell you to replace anything.
I just want to see if the fan turns off before we discuss possible failures.
Did you remove the wires?
May 24, 2018 at 6:45 AM
