air conditioning
1992 DODGE DAKOTA
180,000 MILES
GREENCHEVYMALIBU
  • 230 POSTS
I have a 92 dakota with out air conditioning. I got a r134a system from a 95 dodge dakota. there seems to be a pressure switch on the high side line of the r-134a system that on the r-12 system there is not one. Can i wire in the high side pressure switch in to the r-12 system?The r-12 system has a pressure switch on the low side and one on the expansion valve. On the r-134a system there is a pressure switch on the accumulator and one on the side side line.
May 19, 2013 at 8:09 AM
you stated no ac in the 92???? please explain if you have a r12 system
roy
May 19, 2013 at 9:22 AM
GREENCHEVYMALIBU
  • 230 POSTS
My truck didn't come with a/c but a 92 dodge dakota is a r-12 system. My truck is set up for a r-12 system.
May 19, 2013 at 2:35 PM
