HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Climate Control
Air Conditioner
Not Working
Air conditioning not working properly
TONYAMSES
MEMBER
2003 DODGE CARAVAN
3.3L
2WD
AUTOMATIC
36,000 MILES
My air doesn't blow unless you are driving then it just comes out the vents but not blowing same with heat.
Thursday, February 7th, 2019 AT 2:46 PM
SCGRANTURISMO
MECHANIC
This sounds to me like you could have a problem with your blower motor. Here is a link to a guide that should pin down what your problem is:
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
Go through this guide and let us know what you find out. We can go from there and provide any additional help that you may need.
Thanks,
Alex
2CarPros
SPONSORED LINKS
Friday, February 8th, 2019 AT 2:05 AM
Please
login
or
register
to post a reply.
Related Air Conditioner Not Working Content
2003 Dodge Caravan Heater Only Blows Hot Air
My Heater Only Blows Extremely Hot Air No Matter What Temperature The Switch Is Set On. The A/c Does The Same. Seems As If The Air Gets...
Asked by
hawright2611
1 ANSWER
2003
DODGE CARAVAN
VIDEO
Fix an Air Conditioning Not Working Video
Instructional repair video
GUIDE
Like any sub system in today's car a problem and be minor or a little more involved, this guide will help you find the problem and perform repairs. You can be the judge if...
Why Won't My Air Blow Cold
My 2003 Dodge Caravan Doesn't Blow Cold Air
Asked by
Taterj1968
2003
DODGE CARAVAN
2003 Dodge Caravan Ac Won't Work In Front
I Have A 2003 Dodge Grand Caravan And When Turning On The Ac For The Front Of The Van All I Get Is A Humming Sound That Sounds Like Its...
Asked by
jamcin23
2003
DODGE CARAVAN
My Heat Only Blows Cool Air, Whats Wrong
My Heat Is Only Blowing Cool Air, The Blower Works Fine And The Van Is Not Over Heating.
Asked by
brian.jolly
1 IMAGE
2003
DODGE CARAVAN
2003 Dodge Caravan Heating System
Heater Problem 2003 Dodge Caravan V6 Two Wheel Drive Automatic 80000 Miles When I Use My Heater It Doesn't Blow Hot Air Unless I Turn...
Asked by
BuntWalker
1 ANSWER
2003
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Air Conditioner - Vacuum Down and Recharge
Air Conditioner - Add Refrigerant
Online car repair manuals
