Air conditioning Freon pressure issue
155,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
MARK FRIZZELL
  • 142 POSTS
I replaced my compressor, (cheaper than just the clutch). No refrigerate pressure at compressor. Installed compressor , put my machine on to do evacuation there's 80lbs of Freon pressure. how can that be?
Thanks, Mark
May 1, 2019 at 2:14 AM
Good evening,
When you hooked up the machine, was there Freon still left in the lines from another job? Most guys do not clear the lines when they are done and leave Freon in the lines.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
May 1, 2019 at 10:37 AM
MARK FRIZZELL
  • 142 POSTS
Got it, the tube orfice was completely stopped up.
May 1, 2019 at 9:28 PM
Good find.
Make sure you replace the dryer and evacuate and charge the system.
May 1, 2019 at 9:45 PM
