Air conditioning
110,000 MILES • 2.1L • 4 CYL • 2WD • MANUAL
RACTON
When on Auto AC the cold air only flows on the passenger side, air flows on driver side but not cold. Would like to know how to fix? Thank you
Great, very much looking forward to a response to my problem ( my car xsi 2ltr manual, hatch) delivers AC cool air to passenger but not the driver vents, all else seems correct with the AC the heater works and delivers as supposed to vents as directed.
Perhaps the fourteen degrees which is the lowest on auth AC is a little ambitious to achieve in Melbourne conditions at the moment where we can be in the mid thirties every second day.
The request is to know how to go about identifying as to why the driver is not receiving cool air while the passenger is.
Rob
Feb 23, 2018 at 5:43 AM
MIKE H R
  • 3,094 POSTS
What I would suspect that there may be a leaf or something keeping the vent for the drivers side from opening, check the vents. Listen to under the dash when the car is running to see if you can hear the vent A/C doors move when you change the switch settings from floor to front vent and to the defrost. Look for any broken wires or bad vacuum lines.
Feb 26, 2018 at 12:50 AM
RACTON
Thank you M_H_RITZEL,
Iwill look at doing what you suggest - will let you know as soon as I have checked
thanks
Rob
Mar 2, 2018 at 10:01 AM
MIKE H R
  • 3,094 POSTS
your welcome
Mar 3, 2018 at 11:23 PM
