Air conditioning not working
170,000 MILES • AUTOMATIC
SABRINALBLAKE
Air stopped working, but it makes a beeping sound every so often.
Jul 22, 2020 at 11:36 AM
When you say the air stopped working, do you mean the air is not longer cold or there is no air coming out of the vents?
The answer to this is a very different issue so we need to clarify that.
Here is a guide that will help and where we need to start if it is not blowing cold any longer. If there is no air then we need to look at the blower motor. Let's start with this and go from there. Thanks.
Jul 22, 2020 at 11:42 AM
SABRINALBLAKE
It is no longer cold, I got the re-charger so I’ll see if that works. I still have no idea why it makes a beeping sound when I open the doors. It may be something in the wiring since a new radio was put in. Not sure though.
Jul 23, 2020 at 3:11 AM
Yeah. The beeping sounds unrelated to the A/C issue so let's tackle that first and then we can start a new post for the beeping. We need to keep each topic to one issue so that others can find the solution to each if they search for it.
Here is a guide on how to add Freon that will help:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Let me know how you make out with this and we can go from there. Thanks
Jul 23, 2020 at 11:25 AM
SABRINALBLAKE
I added Freon but it stills blows out hot air. I drove for a little and it started getting colder but barely.
Jul 23, 2020 at 12:38 PM
Okay. Does the compressor come on and off when it is doing this? The other thing we can do is check the pressures of the high and low system to see if it is properly charged and if the compressor is operating properly.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
If the compressor is coming on and off, then we definitely need to check the pressures when this is running because depending on all this the compressor may be the issue.
Jul 24, 2020 at 8:10 AM
