Air conditioning blowing hot air
9,433 MILES • V8 • 2WD • AUTOMATIC
BEVERLY BEST
When AC is turned on it only blows hot air through the windshield vent.
Jul 9, 2019 at 9:35 AM
Good evening,
I attached a vacuum line diagram for you to view. You most likely have a vacuum line off under the hood by the tank that holds vacuum. When this happens, the system defaults to defrost and heat.
Check all the lines carefully.
Jul 9, 2019 at 9:47 AM
