Air conditioning
168 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JUNE SHREVES
  • 6 POSTS
I have had to replace the blower motor and afterwards water is leaking from under the dash into the passengers side floorboards and now it is coming through the air vents.
Aug 6, 2016 at 4:44 AM
WRENCHTECH
  • 20,758 POSTS
If it is coolant, you have a leak in the heater core. If it is clear water, the condensation drain must be clogged.
Aug 6, 2016 at 7:44 AM
JUNE SHREVES
  • 6 POSTS
It is not coolant. It's clear water. It's ice cold water and Orr only happens when I run the a.c. in my car. My nephew has tried to use a wire clothes hanger to see if the Condensation drain was stopped up but he said It felt clear I don't know what else to check
Aug 23, 2016 at 8:03 AM
WRENCHTECH
  • 20,758 POSTS
You will have to pull back the carpet and get your head up under the dash to find the spot where it is coming out. Either the drain is clogged or the case is cracked or broken.
Aug 23, 2016 at 8:09 AM
JUNE SHREVES
  • 6 POSTS
What case are you referring to
Aug 23, 2016 at 8:40 AM
WRENCHTECH
  • 20,758 POSTS
The case/housing that holds the evaporator, heater core and all the duct work is made of plastic. https://www.2carpros.com/images/external/150817329.gif
Aug 23, 2016 at 8:44 AM
JUNE SHREVES
  • 6 POSTS
Could that have possibly been broken when the blower motor was replaced the first time because it did not start leaking until after I had the blower motor Replaced
Aug 23, 2016 at 8:46 AM
WRENCHTECH
  • 20,758 POSTS
It's possible if the guy really didn't know what he was doing but it's not a common thing. Like I said, someone needs to actually look.
Aug 23, 2016 at 8:48 AM
JUNE SHREVES
  • 6 POSTS
Can i find the case on rockauto.com. cuz i would like to repkace it when i replace the blower motor.
Sep 14, 2016 at 3:11 AM
WRENCHTECH
  • 20,758 POSTS
No, forget that. Changing the case is a MAJOR operation. The entire dash has to be removed and the AC has to be evacuated. The case would cost hundreds of dollars and it's only available from the dealer.
Sep 14, 2016 at 3:37 AM
JUNE SHREVES
  • 6 POSTS
What can I do then I've already had to replace the blower motor twice
Sep 14, 2016 at 7:11 AM
WRENCHTECH
  • 20,758 POSTS
You can do as I originally instructed and find out where the actual leak is. Then you can decide how to fix it.
Sep 14, 2016 at 7:24 AM
