Air conditioner runs all the time
145,000 MILES • 2.1L • AUTOMATIC
FRED BOLING
  • 14 POSTS
i have the car listed above LS model. None of the switches will change any function. Had to remove the fuse in the fuse panel to stop it air conditioner. What can I do?
Nov 2, 2019 at 7:27 AM
Good evening,
Do you mean the fan stills blows all the time?
Do you mean the controls will not work?
Can you be more specific of the issue?
Nov 2, 2019 at 10:10 AM
FRED BOLING
  • 14 POSTS
If I put the fuse back into fuse box the air conditioner continues. To run full blast cold. You can't change with climate control switches.
Nov 2, 2019 at 12:00 PM
FRED BOLING
  • 14 POSTS
You can't change to heat.
Nov 2, 2019 at 12:02 PM
FRED BOLING
  • 14 POSTS
No.
Nov 2, 2019 at 12:04 PM
FRED BOLING
  • 14 POSTS
Anything else?
Nov 2, 2019 at 12:07 PM
Still not clear.
Can you get defroster to work?
Will it go to the floor when you command it?
I am trying to determine is it is the climate control head or something else.
Nov 2, 2019 at 10:26 PM
