After driving for about an hour the A/C stops blowing air out of the vents?
130,000 MILES • 4 CYL • 4WD • AUTOMATIC
DUDESSE64
A/C works fine until you've been driving for about an hour nonstop. At this point it seems like the vents are all blocked. You can hear the A/C blowing full blast, but nothing comes out the vents.
Thanks, Lori
Aug 11, 2022 at 5:42 AM
  • 55,580 POSTS
This happens when the system is just a little low on refrigerant, it causes the evaporator to ice up due to the excessively low pressure. Here is a video that can help you add a little to your car:
https://youtu.be/uZrQCGwXfek
Aug 11, 2022 at 10:41 AM
DUDESSE64
Sorry to not answer sooner. This did seem to solve the problem. Thank you!
Jan 14, 2023 at 4:29 AM
  • 55,580 POSTS
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Jan 14, 2023 at 9:15 AM
