Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Lincoln
Navigator
Climate Control
Air Conditioner
Not Working
Air conditioner not working
2005 LINCOLN NAVIGATOR
150,000 MILES
DRAKESWILLMAKE
MEMBER
1 POST
Good morning, the A/C condenser is not engaging. do you know where the A/C relay is in the vehicle listed above four wheel drive with rear A/C?
Jun 22, 2020 at 8:44 PM
Experienced Mechanic
Good morning,
I attached the location of the relay in the relay box for you.
I doubt it is the relay. You need to check the Freon pressures to be sure you have the correct pressure for the system to work.
I attached a wiring diagram of the compressor circuit for you as well. If you have a test light or voltmeter, we can do some testing to find the fault.
Images (Click to enlarge)
Jun 22, 2020 at 10:10 PM
Add image or video
Ask a new question
Engine won't start
Air Conditioner — Not Working
