Air Conditioner noise?
77,000 MILES • 3.6L • V6 • AUTOMATIC
JLAR12
  • 6 POSTS
When the air conditioner is running, the car sounds like it is taking a "deep breath" every 15 seconds or so. like it is being pressurized over and over again. The system stays cold and everything else seems to be working fine.
Aug 3, 2023 at 12:36 AM
  • 55,743 POSTS
Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response. Do you have any warning lights on?
Aug 3, 2023 at 6:55 AM
JLAR12
  • 6 POSTS
Thank you for your quick reply. See attached video. It happens around the beginning of the video and again near the end. This has been happening for about the last month on both extremely hot and cool days.
It’s also worth mentioning that this past weekend I was driving about an hour away (very hot out) and the fan speed dropped to 50% and I had the white mist out of the vents (still cold). Car never overheated however the coolant was low. Added coolant the next day and those issues went away but this sound stayed.
Aug 3, 2023 at 7:24 AM
JLAR12
  • 6 POSTS
Video
Aug 3, 2023 at 7:43 AM
  • 55,743 POSTS
I didn't see the video, but the fact it loses air from the vents and white mist is telling us the system is low on refrigerant. The low side pressure is too low, and it causes the evaporator to ice up. Please go over this video to see how to charge the system.
https://youtu.be/4EqdrBVb0sY
This should fix the problem.
Aug 4, 2023 at 3:59 AM
JLAR12
  • 6 POSTS
Thank you very much. The low air flow and white mist only happened one time and once I added the coolant that went away. The attached video (should work this time) is currently the only issue. Which is the “deep breath” sound.
Aug 4, 2023 at 9:14 PM
  • 55,743 POSTS
Thanks for the video. it sounds like the expansion valve maybe cycling, I would like to install a set of A/C gauges to see if the high side pressure changes when this sound occurs. When you said I added coolant did you mean refrigerant? the system may be overfilled?
Aug 7, 2023 at 2:30 AM
JLAR12
  • 6 POSTS
No, I added antifreeze / coolant (50/50) it was very low. When it was added the other issues went away but not this issue. I really appreciate you looking into this.
Aug 7, 2023 at 2:37 AM
  • 55,743 POSTS
No problem, I think the A/C system may be a little low on refrigerant but if you connect a gauge set, we can tell for sure. Please check out the video in the above post.
Aug 8, 2023 at 3:00 AM
JLAR12
  • 6 POSTS
I hooked up the gauge and it seems to be okay. (See photo)
Aug 9, 2023 at 9:45 AM
  • 55,743 POSTS
You need to see the high-side pressure, but I would give a little more to be closer to the top of the green area. Please let me know.
Aug 10, 2023 at 3:43 AM
  • 55,743 POSTS
anything?
May 6, 2024 at 5:27 AM
