Air conditioner leaks
69,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
CARLTON TROSCLAIR
Leaks at the lines leading to rear A/C.
Jun 8, 2022 at 6:58 PM
SQM
  • 6,383 POSTS
The A/C line can leak at the joint due to a bad O-ring or it can leak at the hydraulic joint, it is where the flexible part of the hose connects to the metal part.
If it is leaking at the O-ring joint, then replacing the O-ring should take care of the issue.
It could be helpful to use a dye to determine the exact leaking spot.
Here is a helpful guide on A/C leak detection:
https://www.2carpros.com/articles/air-conditioner-leak-detection
Before the line can be removed the A/C system needs to be discharged.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Let me know of any questions.
Jun 9, 2022 at 1:53 PM
